The Grim Reaper may fly again!
jetpackninja
More combat please...
This is what the Grim Reaper looked like the last time I flew it. I think a propeller hit the ESC, I lost power after a combat hit and made a gentle dead stick landing. it started smoking as I was walking up to the plane. Yeah, I thought I was gonna retire it but it never found it's way to the trash.
I chopped out all the burned up section and pulled off all the laminate, extreme tape and packing tape.
Glued the two pieces of wing I had left together.
Fixed a whole lot of holes from prop strikes including a big one that was all the way through the wing (gorilla glue mixed with water).
Extreme taped and laminated the wing, remounted the motor ( the only piece of electrics that was reusable). Cut down the elevons. and rehinged 'em.
a4785741-3-DSC04983.jpg a4785742-36-DSC04984.jpg a4785743-75-DSC04985.jpg a4785744-230-DSC04986.jpg
jetpackninja
Thanks man. I just hate wasting a perfectly good plane.
Yeah- It would have been just as easy to re-kit, but I think it turned out awesome.
I trashed my old and many times repaired slow stick a few weeks ago. It's another one that never made it to the trash can ;)
I took a quick look at it tonight (it's the only night plane I have right now) and spent about 10min fixing it up.
I think it's good to go too ;)
jetpackninja
Stainless steel (as supplied in the kit). I have managed to bend one but was able to bend it back.
Haven't managed to break one yet ;)
It's good stuff, some of the guys drill holes in 'em and grind them down to save weight.
I figure the way I fly I need all the help I can get...
#8
Ok, I am currently building a flying wing, do you think the steel has better survivability than ally for combat? I have a stock of ally, but could go and get some of the steel if it is much better
Cheers
jetpackninja
Cheers
Definitely steel! it can be bent back multiple times even after horrific crashes.
Aluminum tends to crack.
So here's a quick one for ya.
Home Depot sells an "L" bracket for 89 cents or some ridiculous price.
Look in their fencing department. The A21 bracket is a little smaller (not as long)
as the ones that come in the crashtesthobby kits.
It is a happy coincidence that it comes with two little holes that line up with the mount on the fc2812 motors that we use and also lines up with the Turnigy 3530. I'll try to post a picture or two when I get home
I wanna see some pictures!
jetpackninja
On the right is the stainless steel motor mount that comes with the Assassin and other Crashtesthobby planes.
On the left is an A21 L bracket from Home Depot.
I would definitely use steel for a combat plane.
I've had one that got bent many times and seems like it just bends easier and easier (so I replaced it), but have never had one fail.
#11
Cool! Cheers for the photos... my wing is not yet photographable however when it is, i'll be sure to post up a pic!
Do you use the 3530 on the Grim reaper?
jetpackninja
Hahahaha- Thanks man. It was headed for the trash can, but I kept looking at it thinking, dang, I bet I can fix this thing.
Sorry guys I didn't get any pics of the maiden but I'm happy to report it flies very well.
Glides like crazy, I had to do a couple of go around again on landings because it didn't want to come down :)
