Cg is 2.25" back from the LE. The wing should span the entire roof evenly. The battery can be either accessed from the top by removing the wing or by pulling the pod out like a drawer. I did the latter because I have 6 rubber bands holding the wing on, becomes a little tedious removing the wing
Like on any to the larger high wings that use rubber bands to hold the wing on, the center of the wing will need to be reinforced to keep the center from folding under the pressure of the rubber band pulling on it. I used pop sticks running parallel to the length of the fuse on either side. Skewers were used as hold downs through the fuse front and back
Sadly again, I would have to have someone Print the Plans for me...
No Computer, no Printer. I know that seem strange these days, but it's that bad here...
I REALLY like this design! It incorporates everything I like in these Planes - especially SIZE!! 🙌🙌🙌👍👍
Plans are being revised again so give it a couple days before you download them, just adding a couple missing components. This should be the last revision though
no all good just some fun. I am sure i can manage the build with out the latest components.. just laughing because i finally broke down and printed the plans last night and then instantly they are obsolete.
