What are you using for servos? Receiver? Are you going to add ailerons?
Oh yeah, I forgot :black_eyed:
Just thinking about the weight, I wonder if you could get the same effect without having a full sheet in the middle. Have a top and bottom, and have the front and back of the center piece but leave out the center, with maybe a rib in the center. I know it's not far from making ribs and spars, but I am curious how much weight you could save. I am going to have to try this airfoil myself, it's very intriguing.
I think that motor would do fine. I was confused a bit by it as well. It looks like they recommend a 2 or 4 cell for higher thrust, and a 3 cell for a little bit less. It sounds a bit odd. I would go with a 3 cell because I like the power, it's a good rpm range and the batteries are cheaper than a 4 cell.
I think that combo with a 1300 3 cell will do fine. I would go with a higher C rated battery, at least 25 in case you end up needing a lot of amperage to make it fly the way you want.
You are absolutely right. Solid wings are not stronger than hollow.Just thinking about the weight, I wonder if you could get the same effect without having a full sheet in the middle. Have a top and bottom, and have the front and back of the center piece but leave out the center, with maybe a rib in the center. I know it's not far from making ribs and spars, but I am curious how much weight you could save. I am going to have to try this airfoil myself, it's very intriguing.
I am always choosing the lightest setup for many reasons. A shorter flight time is no problems for me. I am (almost) never using all the battery capaicity. If i am flying pattern then it is not easy to be fully concentrated for more than 5 minutes. I never fly pylon (= full throttle all the time). It is better to land and replace a battery to a new fully charged than carry a lot of dead weight. My choise of battery to a plane that size is normally : http://www.hobbyking.com/hobbyking/store/__11899__Turnigy_nano_tech_850mah_3S_25_40C_Lipo_Pack.html.
The supplied connector is crap if you need 25A so i go for the http://www.hobbyking.com/hobbyking/...0_Connectors_Male_Female_5_pairs_GENUINE.html.
