davyg
Started building a new Quad, just waiting on the USB ASP so as I can reflash the board to X-copter configuration (pay attention to hobbyking website location next time I order....LOL... HK instead of UK.... DOH!)
arms are 15mm basswood with 2 x 50mm end pieces glued and then drilled and then I added 4mm wooden dowel with wood glue for extra strength, also added 1mm double sided foam to the top and then stuck on 3mm ply to give a solid base for the motors, which are held in place with 2.5mm zip ties, body is 3mm ply, I used M4 X 30 nylon plastic bolts/washers/wingnuts. and drilled 10mm holes to pass the ESC plugs through
used an old DVD tub as a protective housing, this was held in place by 2mm x 20mm bolts with nyloc nuts.
Orientation/navigational aids consist of green/red electrical insulating tape, and for the rear it is 4mm wooden dowel pushed through a piece of pool noodle (I drilled about 6mm into the side of the rear arms using a 4.5mm drill bit).
I implemented Rcexplorers battery and camera mount and glued a piece of non slip matting to keep the battery in place.
Total weight of the copter incl battery and motors (without props and prop mounts) is 950g ......lets hope this things flies... as I never ever managed to get my Tricopter build off the ground properly....
