Just got my kits today...
The base kit comes with the following:
* The laser cut foam pieces (3.5 pieces of foamboard)
* landing gear wood supports (these are embedded in one of the foam pieces)
* Decal Sheet (Red stripes and some checkerboard). I didn't expect this so it's nice.
* Window vinyl sheet, though mine came outside the shrink wrap so I suspect it's a late addition.
* Info Sheet
* Build Pack (or whatever they're calling it). A long thin padded envelope. Not everything in this kit is needed for the build. I think these are generic packs thrown in many of their kits.
The Build Pack has:
* 6 popsicle sticks
* A paint stirrer stick
* 6" Velcro
* 18" Servo guide tube
* 4 mini zip ties
* 4 bbq skewers
* 5 thick rubber bands
* A plastic firewall
* A pack of servo horns
* A wire pack consisting of 4 servo wires, 2 gear wires and 1 wire in between the two
From the video it appears that in tricycle configuration the front wheel just pivots on a caster type design, so should hold straight when going straight, but pivot in a turn with the rudder. I'm sure it could be attached to a servo for steering, but it's not specifically designed that way. This plane is designed so that you can remove and swap landing gear configurations if you want to and that would be difficult to do with something attached to the front wheel.
There are NO WHEELS included with the base kit, so you'll need to order the wheels you need for the design you are aiming for. I have a set of big wheels from an earlier Simple Cub so I'll be making the tail dragger with those.
