Beaver5150
This is another build thread of one of my ongoing contraptions, the left-over airframe from the Stinger Tri-copter I ran for a few months. I decided to resurrect it as an airplane similar to what I did in the building of The Mongrel Project.
It will be 0.80, or 4/5 scale from the size of Mongrel by the current calculations.
Single motor in tractor configuration, Emax Eco-II 2807/1700Kv/7x4.5x3 prop with airframe fitted for 3S/2200mAh or 4S/2300mAh LiPo packs. The thing should have plenty of power. Motor is factory rated at 1500g on 4S, and target weight is 1000g AUW.
The landing gear has been revised twice up to today, based on leftovers of a cheap RC rock crawler with hand fabricated axle and trailing link/sway bar. Wheels subject to change. I try to keep a wide track for stability, yet the geometry should absorb the harder landings I inflict when pulling STOL maneuvers. It also has to have the "Bigfoot" stance just to keep that 7" prop off the ground. The mud tires just look cool..... bush plane..... mudders..... Yee-Haw!
I have yet to settle on wing and tail profile, but wing will be 48x8, for a light wing load. All preliminary airframe and wing dimensions coincidentally fell into a 80% downscaled Mongrel after doing some comparative calculations, so I'm going to run with it.... Mongrel specs are working perfectly for me, so why change?
Here are the current photos of Phoenix.
Yes, that is a helicopter gyro on the back..... and it does work for fixed-wing if properly configured.
Nearly ready for wing and tail.
This thing is already functional by the Tx/Rx/FC and ESC setup. Static thrust test imminent.
