mayan
I went out to the field today and it was a bit windy and late so I decided to practice general flying instead of ground take offs and landings. I started by doing leveled high and low circuits at 50% throttle. Then I practiced doing rolls, when at full throttle the rolls were tight and clean when the throttle was lower at around 50% some up and down elevator was required to keep the plane from losing altitude and diving. Not sure that’s how it should be.
After that I practiced loops and those require you to nose dive throttle up and pull max down elevator until at the moment that you are at the top of the loop and then you should throttle down and level out. Didn’t spend much time doing that because I am having battery issues and didn’t want to go max throttle to much. I think the problem is actually my motor dying out and that effecting my battery buzzer making me think it’s the batteries when it isn’t.
Last I practiced inverted flying and this is where I need more practice but some assistance too. I can flip inverted and fly straight my problem starts when I want to turn. That’s when I find myself failing and end up diving inverted into the ground. How do you turn when inverted!?
