Yesterday I went to the field and despite a bunch of mishaps had a great time. The day began with a rain that started just as I finished packing the car. There was a moment when I debated if to go or not but decided to just go considering I was already up, dressed and at the car. I also managed to convince a friend to tag along so I was definitely not backing out now. On the way to the field the rain didn’t stop in fact it seemed to be quite strong, but it was all a big show because a few moments after I got to there the rain stopped.
Happy with the situation I started preparing the Spitfire for a maiden with a 3S battery inside. The maiden went great but considering I finally had a friend tag along something bad was surely going to happen. I flew the Spitfire like I stole it doing fast and slow low passes, low loops and rolls. It was after I recovered from a lost of orientation that my attempt at an inverted low pass wing tipped me into the ground, which caused the firewall to part from the power pod.
Since my field repair hot glue gun isn’t working I had to improvise a repair and used a hot glue stick and lighter to get the job done instead. The battery was empty too so that went out and a new one went in a 4S this time
. Up we went again with a quick circuit around the field and suddenly silence and something came flying out of the plane taking a slow fall to the ground. Luckily I was able to land the plane as I still had power on the servos and ran to check what happened. At first I thought that only the prop came loose because of the slow fall to the ground but when I got to the plane I found out the entire motor was missing. I searched for the motor for a while but couldn’t find it, so I took a break and went to fly something else.
Next in line was the FT Stem Charlie, flying with a 3 blade 5x4.5 prop and a 1000mah 3S battery was nosy enough to draw in a crowd for my head over low passes show off. All of which went great until the battery was empty and I brought the plane down for a landing. At that point one of the people watching came up and asked if I built them myself and if I was selling them. The answer to the first was easy the answer to the second a little less. Never knew what to answer to that question, never knew how to price it, if to see which or without electronics? Maybe the way to go is charge for flying training, and make the build process part of it? Don’t know, but one way or the other I gave him my number and told him to talk to me. Here is a short video of the one of the head over low passes that I did, enjoy.
Having a crowd made me go all in and take out the FT Goblin with a 4S battery. The Goblin flight was fast, short and scary; the plane was uncontrollable and crashed out of sight a few hundred meters away from where I was. The damage well let’s just say that it doesn’t look good but I still haven’t checked it out.
At the end of all this I went out for another search around the field for my missing motor. After exactly 50 minutes of weaving the field back and forth I found it, my missing motor and prop in perfectly good condition
. Lucky the ground was soft because of the rain at the beginning of the day and that cushioned the fall.
