Headbang
Pretty sure it was a 500w hobby king motorI totally get it - hopefully 2021 leaves you with more flying time. What motor did Lane use in his?
The servos go on the interior where the servo marks are located, and then the pushrods go to either the rudder or elevator. You decide which side they go on. And the tail just slides into the slots on the rear fuseI dont suppose a less frenetic version of the build video is possible? I love Josh's FT build video, if only you could actually buy one of theirs, or print their plans...I've done 3 or 4 scratch builds so this one was mostly self explanatory, but I'm a little lost on the Tail/Fuse servo and final assembly. Some people have their servos on the exterior, some interior, etc. I'm having a hard time determining how and where the pushrods are routed and mounted. Also the whole tail assembly rudder/elevator to fuse is a little unclear.
Love this design. It was easy to print out the tiled plans, and I cut them out and mounted them to posterboard and made templates for future builds/parts. None of that 72 page craziness. and it only required 3 pieces of Readyboard.
Thanks Hangar. I live in Washington too, Snoqualmie Valley, so I may have to do a pontoon version in honor of our floods.
My only issue with them is I think I will have to super glue the attachment pin so it doesnt pop open and come loose.
does anyone use these inexpensive Power Packs from Aliexpress?
Instead of glue, you can use a small piece of silicone tube, or even a rubber band used for dental braces. I like the silicone tube best.I dont mind a z-bend when its the best option, but given the opportunity I like something I can make quick adjustments on. These came packaged with some control horns I got off Amazon. They accept a decent diameter rod. My only issue with them is I think I will have to super glue the attachment pin so it doesnt pop open and come loose. But the screw allows you to make really quick length adjustments easily.
I'm trying out these hinges on the elevator and rudder. I got variety of sizes from Amazon and Aliexpress.
Speaking of which, does anyone use these inexpensive Power Packs from Aliexpress?
I am building this plane with all the Chinese budget gear. $10 power pack, $12 6-channel receiver, $16 gyro. If it doesnt burst into flame it might be quite a dandy little trainer.
Since the day I got into the hobby and built my first plane somewhere in the 80's we have been using fuel tubing to hold clevises. Never heard of it failing. Have had things fail when I forgot to do it tho!Thanks, I'll have to see if I have some tubing, looks like the perfect solution.
I actually tried to make a build video but lots of my footage didn’t save. But thanks for the reminder - I’ll definitely put that on my list to do! And I’m glad to hear the plans and all worked out well for you! If you do floats you’ll have a lot of fun with them - I sure did!I dont suppose a less frenetic version of the build video is possible? I love Josh's FT build video, if only you could actually buy one of theirs, or print their plans...I've done 3 or 4 scratch builds so this one was mostly self explanatory, but I'm a little lost on the Tail/Fuse servo and final assembly. Some people have their servos on the exterior, some interior, etc. I'm having a hard time determining how and where the pushrods are routed and mounted. Also the whole tail assembly rudder/elevator to fuse is a little unclear.
That’s awesome - scratch building is addicting! The pictures of the tail you sent look great. I really like how you did the hinges.This was only my 5th foamboard plane, and 3rd scratch build from tiled plans. I did the BN Versa and a regular one, and then this one. You learn so much. I've got it fully built and ready to fly, print to power up in two days. If it survives the maiden I'll paint it.
Huge thanks to @tanmaychhatbar for making a realflight model of the simple stick! I had a blast flying it around last night. The model can be downloaded here:I found on Knife Edge Swap Pages that a guy made a simple stic View attachment 189739 View attachment 189740 View attachment 189741 View attachment 189742 k for real flight! It flies similarly to my old one and is a blast to fly!
I didn't cut any thrust angle into the pod, but instead I just added a small washer behind the motor mount to the top and left side to give the motor a slight down and to the right angle.I haven't built the firewall yet but do we need to put any type of thrust angle into this POD ?
It flies great without any thrust angle. If you want to add a touch of down or right you can, but it's not necessary.I haven't built the firewall yet but do we need to put any type of thrust angle into this POD ?
