Another micro sized plane. Needed to add a wing to the lineup, and wanted something that looked a little bit different. And hey, it's October!
Same electronics, though I may use some bigger servos. Maybe 3 grams, as the control surfaces are huge (it works on larger epp wings, we'll see how it does here.)
Setup from the start to use nerdnic's Manic Micro sized power pod. But, you can certainly fit a different type of mount on there.
18.5" Wingspan
Vertical Ground Launches
6.4g HD1610 3400kv Motor
5030 Gemfan Prop - 5" Maximum Prop Size - Slot is just over 5"
6AMP Plush ESC
3g Servo x2
Full Receiver
Gift Card Firewall and Servo Horns
180-260mah 2s
I have 3 planes to build this weekend. We'll see if I get to this one.
18.5" Wingspan
6AMP Plush ESC
3g Servo x2
Full Receiver
180-260mah 2s
