"The Towel" Brooklyn Aerodome
I heard of "The Towel" (or to the Brooklyn areodomers, the Flack) wingplane a while ago in a MAKE issue, and I ordered some of the parts and am going to build it. Can you guys do a review, Or has anyone else built it and thinks it is awesome?
jhitesma
Some guy in the desert
I almost built one. That issue came out right at the same time I discovered FT which was also right when they released the nutball as the first swappable. I had already ordered some parts for the towel - but then when I saw the nutball and the promise of the swappables I decided to go with the nutball/swappables instead. Took me a few months to remember what I had ordered that particular motor for :)
I'd still like to toss one together one of these days, but I don't have a good source of coroplast (at least not that doesn't have political BS on it) and DTFB is so cheap I've just been focused on foam planes instead.
#3
My son and I started with the Towel this summer and had a ball with it. We went thru three airframes before we discovered FlightTest and we haven't looked back. The towel is pretty tough and you will be amazed how long you can fly one even after severe crashes. Just add some packing tape and off you go. I also really like the coroplast module idea as it made swapping out airframes very easy.
The downside to the Towel is that is isn't the most stable aircraft and without landing gear, every landing is basically a controlled crash. Even if you are good at flying it, just a little error on landing and you will be crushing the nose or bending the wingtips. Also I ended up buying a full 50' pack of blue Fanwood foam from Lowes for ~$45 because I couldn't find any local source for a sheet or two.
Once we discovered flitetest, we built two nutballs because they were starter planes and my son thought they looked like a lot of fun. We bought recommended electronics for the swappable and went flying. Our experience is the nutball is anything but a good beginner plane. Very unstable and very susceptible to wind. We then built FT Flyers and that is when we REALLY started enjoying flying. FT Flyer is an awesome beginner plane as countless others have stated here. The flyers were the first planes we felt like we were actually flying and we were finally able to go thru entire batteries with no crashes. I've flown mine (with landing gear) easily through 20 batteries and there literally isn't a scratch on it.
So where am I going with this? I loved the Towel and am grateful it allowed my son and I to get into RC cheaply and with no fears of crashing. I am more grateful that it led me to Flitetest! So if I had to do it all over again, I would recommend starting with the FT flyer because it is simple to make and repair, cheap, stable and also will give you the electronics to move to many other FT designs.
