Joexer
So I've decided my next plane will be an FT Goblin, but I would like it to be a bit more LOS cruiser than FPV racer as it seems by default. I am almost obsessed with stall characteristics because I enjoy flying rather slow, hovering into the wind and the like. I also happen to adore the stall characteristics of Planks and Forward Swept wings. I've come across a couple mods and considered a few new ones I have questions about. Considering A basic Setup with a 2200mah 3s, 2205 2300kv motor and 6040 prop, Would any of the following have detrimental impact on the model?
Considering Buying one kit and scratchbuilding a second as a mod testbed as well, but if theres something not worth trying I'd like to know if/why. In pursuit of Knowledge .
- Extended Wingspan
Pretty self Explanatory, probably around 200mm airfoil extension on either side added at the root for lower wing loading and to provide for Reflex - Vortex Generators
I have used Vortex Generators on just about everything but a Plank style-wing, to increase stall AoA, is there any reason not to (besides parasite drag) - Wing Strakes
Applied to Nose Cone and Joined to wing to provide better stability at High AoA.
