Moiraobrien
I received my Jumper T12 this morning and set about loading two of my models. All went quite well until I started trying to edit the throttle settings. At first the throttle was running as soon as the model was bound. I was trying to edit the mix setting to reduce the throttle to zero when the gimbal was at zero but then the throttle stopped working altogether. Now, as soon as any model is bound, I get a Throttle Warning, but the throttle is not set to any gimbal, switch or Aux - at least not that I can find.
I decided to update the firmware to v2.2.3 to see if this solved the issue but it didn't and now my screen display is inverted.
I couldn't find a solution on the OpenTX forums, or anywhere else.
Can anyone help?
thanks
Moira
Can anyone help?
thanks
Moira
