Thrust angle for FT Tenet, tractor build
STCSTEM
Hi All,
I have just finished my build of the FT tenet with the motor at the front - does anyone know what thrust angle to use in this configuration? My apologies if I missed it in the video but i cant seem to find it anywhere.
The little removeable motor mount is quite clever - I was going to assume it should point to the right like the Tiny Trainer but would appreciate a confirmation before the first test flite goes potentially horribly wrong...
Thanks
This is a top view of how it should be,
Tradition holds about 3 degrees right and 2 down. In other words couple thin washers on the right top if you mount in X configuration. If you go from cruise to full power and it just goes faster with no need for any trim change it's close enough.
