I built mine to spec, and it seems like it will never get off the ground. Don't touch the elevator until you reach speed, then it will leap in the air. Also, be careful to give down input after it is a few feet off the air because you may end up stalling. The Sea otter is a great plane for flying low to the ground and doing tight coordinated turns. I would also add stall fences to the wing.
