As said check your incidence angles, thrust angles and control surfaces including the ailerons.
This is so true especially with the SeaDuck. The motors centre of thrust is above the wing chord which means with throttle, a lot of airflow will be above the wing creating artificial lift.
It can be minimized with experimenting with variations of incidence, thrust angles, trim, CG and adding a throttle/trim mix.
