I am having a similar issue, although vibration only occurs at high throttle. I recently replaced the motor shaft (Bent it pulling up while flying inverted... Wrong up). Does the fact that there is no vibration when running the motor clean simply indicate an out of balance prop, or is it possible that putting a load on the motor can cause it to vibrate if something isn't right?
