Wow...thanks for taking the time to pass this on. My batteries have the BEC so I figured out that the battery port on the receiver wasn't going to be used so all the connections to the receiver have been sorted and I was able to at least confirm the throws on the control surfaces and they're all centered except for one aerliron which will need a bit of adjustment...or I suppose I could center and move the horn.
For batteries I have 2 3S 2200mah batteries and a smart charger I picked up on Amazon to get me started. AC adapter but no DC operation. Looks capable of charging up to 6S. It's programmable and has some memory for the batteries normally charged. When I got the batteries one was at 7.3 volts and the other 11 volts. I read somewhere that max charge should be 3 times the cell voltage-which I guess is 3.5 volts. Now the batteries are nominal 11.1 so I'm not sure exactly where to stop. Probably not "future resistant" but looks to be pretty decent for now. But this answers another question bouncing around and that is how many batteries are enough...I have 2 but looks like I might need 2 more. I don't know what the flight time is per battery yet (obviously throttle usage dependent) but I'm betting two isn't going to cut it unless I'm able to recharge on-site. Our field is pretty rudimentary and a lot of weekday flying is done off a local soccer pitch (with approval of Parks department) so more is probably better than less.
Sounds like the 6 channel Spektrum will hold me for a while. Very popular with the local club members as well so a pretty good knowledge base to fall back on. Hope to have that in another week or so.
Ooooh, let's provide some education and basic safety for those batteries right now so that you don't burn down your house or have batteries explode. I know several people in different clubs who have had batteries explode on them, start fires that took out their garage or den, and I don't want that to happen to you.
Let's go over the basics:
1s, or 1 cell batteries, have a nominal charge of 3.7v. When charged up to "full" and ready to fly, that translates to (in theory) 4.20v. 2S batteries are 2 cell batteries, and they are basically doubled, so would be 7.4v - when charged, would be 8.40v. 3S start at 11.1v, and when charged fully, would be at 12.60v. To do the math, any lipo cell battery is 3.7v times the number of cells, which gives you the nominal voltage. Multiply that 4.20v times the number of cells, and you have what the fully charged rate is for the battery, so we could use that to go to 16.80v for a fully charged 4S, or even jump up to 25.2v for a fully charged 6S battery.
The mah that you see printed on a battery is like the capacity of the battery, or how long you can fly with it. A 2200mah battery will,
in theory, let you fly longer than a 1000mah battery, because it's more than twice as large. (However, that 2200mah battery is also going to be larger and heavier than that 1000mah battery, so it's going to add drag to the plane, and it's not going to give you flight times that are twice as long).
So, now we have to look at how fast, or how much amperage, you can put into a battery to charge it. This is where it gets dangerous. Some manufacturers will print on their batteries that they have a max charge rate of 3C. I don't recommend ever charging at 3C on a battery; it can shorten the life of the battery, induce puffing on the battery, and could potentially cause it to explode in a literal fireball. Other people might tell you that they've charged high C rates with no problems; I'm going to tell you to ERR ON THE SIDE OF CAUTION. Seriously. It might take less time, but if it means a much lower risk of your house catching on fire, it's worth it.
So, to get back to what I mean by 1C or 2C or 3C charging - this is the amount of amperage you can use to charge your battery. Amperage is based on the milliamp hours for the battery itself; a 700 mah battery charging at 1C would be 0.7A, a 1000mah battery at 1C would be 1.0A, and a 2200mah battery charging at 1C would be 2.2A. This amperage amount rule is the same, regardless of whether it's a 1S, 2S, 3S, etc. battery. Now, you CAN charge it at a higher C rate, but it's dangerous. The best way I can paint a picture of this is that if you were to fill up a water balloon with water from your tap - put a lower flow of water in, you can fill it up and not have it burst, but as soon as you crank up the pressure to full on the faucet, the balloon fills too fast and it explodes all over, leaving you wet, right? Well, lipos charge in much the same way - except with too much energy, they explode with the burny burny fire stuff, not water.
Wattage plays in with this math equation: W/V=A. That is, Wattage, divided by Voltage, is the max Amperage output. So, a 50W charger, charging a 1S battery at the fully charged Voltage, would give us 11.90A as the max amperage we could potentially have. That's great, right? Not when we increase the voltage of the battery. A 2S battery would be 50W/8.4V, which equals roughly 5.95A max. 3S would be even more limiting - 3.97A. As we get to more cells, that decreases the max amperage quite a bit, to where that 50w charger isn't going to be enough to charge that battery. A 6S, 5000mah battery being charged on a 50w charger? Over two and a half hours, with 50w (5000mah/1.98A=2.53 hours, from 0 to 5000mah, IF the battery were ever actually that dead, which should NEVER get down to that level - if it does, don't try to charge it, recycle it).
So, try to charge your batteries at that 1C rate, and bring them down to a storage rate, which is 3.8v per cell. If you don't have a cell voltage tester, buy one; they're cheap, and they're a good way to get an idea of how long you can fly. I like this one here, because it has some extra features built in to it, and you can see the charge for each cell, which helps to tell you if you have a potential bad cell or unbalanced battery:
https://www.amazon.com/dp/B0178P8H9U/?tag=lstir-20
Lastly, ONLY EVER CHARGE A LIPO ON BALANCE CHARGE SETTING!!! If your battery is not balance charged and you have a cell with a significantly lower voltage than the others (say, two of your 3 cells are at 11.8v and one is at 11.3v) and you try to charge it up, it could cause the battery to "overcharge", and explode. Better to be safe than sorry!!!
