Timmy
CRASH LOG
Plane | Media | Pilot | Cause of Crash | Damage | Date |
Delta Ray One | None | My dad | He's never flow, and he smacked into a tree | Twig hole in the wing (minor) | May 21 2019 |
Delta Ray One | None | My dad | His second flight and he cart wheeled. | None | May 22 2019 |
Delta Ray one | None | Me | My first flight and I cartwheeled | Wing Ding (minor) | May 24 2019 |
FT Sparrow #1 | None | Me | Smacked into a tree | I don't remember | ? |
FT TT # 1 | None | Me | Nose dived into the ground due to me being stupid | Broken prop and crushed nose section (moderate) | February 2020? |
FT TT # 1 | None | Me | Direct hit to the motor from a fence post. | Weakened coil (which later broke), ruined nose section | March 2020 |
FT Guinea Pig | There are pictures but I'm too lazy to go and find them. | Me | Aileron, and both ESC wire got unplugged from receiver. | Prop scar on nose, fire wall broke off. | June 2020 |
FT BW | Me | I was learning and over stressing | Various dents and creases everywhere. | I don't remember | |
Delta Ray one | none | Me | My friend launched it in a spiral | Broken nose (severe) | August? |
FT Otter | None | Me | Throttling up to quickly resulting in loss of control | Dented nose (minor) | August? |
Hangar's F7F Tigercat | Me | Ailerons being weird. I crash landed in a low branch on a tree instead of the ground because I thought it would be softer. I chose the right option. | Wing ding (minor) | Late August? | |
FT MS Corsair | None | Me | Reversed ailerons | Scrunched nose, displaced spar, creases everywhere. (moderate) | Late August? |
VR-3 Tree Slapper | @RC4Crashes | I think the power pod was loose but I wasn't the one flying. | Brown nose, dirt in motor, broken thingy that slides onto motor axle and hold prop in place. (moderate) | Oct. 5th, 2020 | |
FT Sportster | Me | I landed on my tail somehow. | One side of the elevator folded all the way up. I also forgot to put in those BBQ skewers. (Minor) | Nov 5th 2020 | |
FT Sportster | Me | I forgot to switch planes in my transmitter and used the wrong settings. | Bottom wing section/wing box broke off, broken prop, bent rudder, grass stains (severe) | Nov 8th 2020 | |
Grunjet | None | Me | Threw it too lightly I think. | Broken V stab, creases, bumps, I had to clean the EDF of debris (Minor) | Jan 9th 2021 |
Grunjet | Me | Not enough elevator throw | Nose is ded. (minor) | March 6th 2021 | |
Grunjet | Me..as usual | I just suck at landing this thing. | Nose ded...again, and the thrust tube came off. Easy to fix. (Moderate) | March 7th 2021 | |
Grunjet..again | Me | I dunno, maybe wind but it started turning right suddenly and into the ground. Did a cartwheel this time though. | Nose ded. My glue joints seem to hold though because it breaks in a different place each time (Moderate) | March 7th 2021 | |
Thresher | Me..duh | I turned up the throttle too quick, it did a roll....into the ground. | Aileron ripped slightly, brown fuse (Minor) | April 14th 2021 | |
Lutra 1.1 | Me | Nose heavy and I threw it too lightly. | Nose smashed, tail boom snapped. (Major) | May 10th 2021 | |
F-22 | Me | I flew too close to the ground and had too little airspeed. | Nose smashed, Minor crinkles overall (Moderate) | Sept 4th 2021 | |
Lutra 2.0 | None | Me | I stalled while gliding due to me being sucky. | Nose smashed, wing tips ripped off due to cartwheel (Moderate) | Sept 5th 2021 |
ST's Modded Ripper | None | Me | Bad thrust angle | creases chipped prop, the usual stuff | Feb 2022 |
CL-415 | *sigh* me | Did not glue in elev control horn and decided to fly anyways. Crashed into a metal garbage can. More details here | Broken prop, nacelle, various cuts and creases, got very lucky. (Moderate) | July 23rd, 2022 |
Note: there are probably more crashes, especially earlier but I just can't remember them all.
