I switched the motor rotational and it worked... finally! So happy to get ny first sicsessful flight. Only problem I've had is that since the motor is spinning in the adverse direction it was designed the spinner nut unscrews itself sometimes. I've found that when the props have an R on them, like "6045R" it means they are reverse props. Now this is where it gets confusing. The prop spin direction is relative to the front of it, unlike the motor spin direction. I think this is because for multirotors you look at the prop from the top down. So, a "standard prop" is actually considered to be spinning CCW.
