Monte.C
I'm designing a foamboard mini WB-57D. Twin 1806 2280kV motors (I'm sure that's more than plenty for this), 26" wingspan, as close to scale as I can get it. The problem is that to fit many of the battery packs we might use it would make the fuse much too fat. I've got this thing to comfortably fit an Ovonic 1500mAh 2S 50C standing on its thin side (I've got two right now). One reason it fits is because it's thin at about 14mm.
I would normally design this with the option for a 3S as well, of course, but for thickness it's looking like the best I can find would only be maybe something around 650mAh, maybe 850mAh.
I expect an empty shell weight at around 90-95 grams. Light servos, light 20A ESCs. The objective isn't speed, but gentle graceful flight. I'll use two aggressive 4" 3-blade props (I know the motors would be happy with a lot more prop).
QUESTIONS:
1. Will the 2S pack give me enough push so it doesn't feel underpowered under any normal conditions? - Coming out of a reasonable dive, etc.
2. What kind of run time could I get out of a 650mAh 3S running these 2 motors?
This forum is the most amazing resource. Used to be all you had was what you could read in the magazines, and some people were local club members and could ask Larry or Bob over there to see what they say. I want to thank everyone here just for being here.
QUESTIONS:
