Bipes can offer a lot of fun things. Adding a cup (glued to a stiff piece of paper) and rubber banded to the upper wing allows you to drop plastic eggs, homemade parachutes or even candy. No mechanism to build, just roll the bipe, go vertical or do a loop so it drop out. Packing it right keeps it in until you are ready to drop. No cover is needed.
It also become a bomb drop so "How close can you land it to you"? Yes, I need to amuse myself and have a goal when I fly. As the FT crew says, go have a good time and lots of fun.
Actually, it allows you to improve yourself in flying. Flying a bipe, precisely requires the rudder and throttle management with the proper addition of ailerons and elevator. Now add a gusty wind and it becomes easy the more you practice. Then I bet you that you can fly almost any plane you build.
