Fuzzy Whumpkin
Just wondering if it would be possible to modify the switch thing that david rigged up to turn on the toaster so that you could have multiple on-board charged batteries you could switch between to extend flight time? Seems like you could have several battery packs allowing for crazy long flight times!!! I'm also curious how the wirign/switch system would work, even just hypothetically....
also - are there build plans available for the inverted gullwing wing (as in, w/o a toaster attached)?
