So, to start modifying the cowl, I'm using a piece of cardboard as a guide. I traced the perimiter of the cowl onto the the surface. I used my compass to draw a couple of arcs... basic geometry here. Draw an arc that crosses over the center of the circle. Keeping the compass at the same setting. relocate it to any other place on the circle and draw another arc. The two points that intersect will create a mid line that perfectly intersects the center of the circle.
This creates a reference for me to mark the cowl for lines exactly in the middle on each side.
Using a square, place the edge along the base of the cowl and draw a perpendicular line to create a center line for our wedge that we will cut out.
Measuring the height of the cowl we then draw out a piece of cardboard to reference/ trace the wedge to be cut out.
Then this is transferred to the cowl and we verify that 1/2 inch at the front lip is the maximum amount to be removed.
Next is that somewhat sketchy part. The razor saw is our tool of choice here. As gentle as I tried, there was still cracking of the plastic due to how old and brittle it was. Still, It's a fairly clean cut and can easily be cleaned up with bondo. After the cut is made, I tacked the two halves back together using medium CA. Due to the curvature of the cowl, the halves do not exactly match up but this was known to happen. I could have made the cuts with more meat left on to sand it flat but with how brittle the part is, I did not want to chance more cracking.
The side profile is perfect and we still have good clearance for the mounting ring. From the top view you can see where we need to add a bit of bondo to round out the opening more. Again, this was known. Also note that because of the modification, the trailing edge is no longer flat to seat onto the mounting ring.
One seam was not tacked so that I have room to flatten the trailing edge, set the gap to maintain a good fit to the mounting ring, and allow for any adjustments prior to final glass work.
All that being said, the process was easy but moving forward, after I glass the seams on the inside and work the bondo magic to clean it up, I will likely glass the outside of the entire cowl with epoxy to give it strength. I'm considering using heavy glass with a finish layer on top. A simple finish layer will not provide much strength. This means more weight, which may not be a bad thing but I do not want to have a situation in the future where chips and dings require me to sand off paint to do this process at a later time. Any kind of damaging nose-over at a field means possible loss of pieces or the cowl becoming a crazy jigsaw puzzle to piece back together.
