Foam Addict
Squirrel member
I found an old TP motor in my basement, and after remembering its lackluster performance on my first plane (2009ish)
I decided to rewind it.
9/10 turns of 24 g wire, every other tooth wound with one extra turn.
Delta termination.
No load current 1.06 amps at 8.35 volts.
KV is around 1100. EDIT: Oops, actually around 2300, I went the wrong way in the Y to Delta conversion.
I'm planning on using it in my harbor freight P-51 if the 9x6 prop doesn't boost the performance enough on launch.(I've been flying in temps no higher than 20 so the density altitude is pretty low.)
Delta termination.
