ok so no matter what i do, when i go to print the plans for the mini arrow, if i select to print the actual size, several parts of the wings will be cut off at the bottom of the page, the only way i can get the plans to print right is when i choose fit to page, but then its scaled down to 97% of the actual plan size, which in turn would make the plane smaller than its supposed to be. Im using the 8.5 x 11 paper and the pdf document size is 7.5 x 10.5 IDK what the heck to do. if i could figure out how to slide the pdf document up on the actual paper it would be fine and the inch and cenimeter legend and tile number would be slightly cut off but the plan would be its actual size. im pulling my hair out!! help!!
Hey Sponz, do you know if there are any plans on going back to some of the old plans and doing updates such as the alignment cross hairs on the mini arrow tiled plans? I first built an arrow, then built a Tiny trainer. the TT did not have the alignments cross hairs and it made for some extra difficulty in taping up plans.
That has always been my plan, yes. If you check my plans index, there is a mix of new FT designs and some of the older back catalog stuff mixed in there. I believe the Tiny Trainer is in there too. Some of them were done with a slightly older version of the template format, but they should still be an improvement over the originals. The link to the plans index is in my signature below.
@jim_W what size do they print? How much? I just paid $30 bucks to have the Raiden prints printed out to plain paper and I still need to transfer to poster board.
Sorry that you are having issues. Every printer is slightly different so there is no way for me to guarantee that they will work with all the different hardware out there. What software are you using to view/print the plans. I would recommend that you use Adobe Reader for printing. The following screenshot illustrates the settings that I have found that work best for printing the tiled plans. Give that a try.
done been doing EXACTLY all of that and it doesnt print right STILL. thanks for the suggestion though. if i print it the 97% scaled down, will the firewall/motor mount be too small for the motor to bolt up?
If you're scratch building the firewall you may have to move the motor mount screw holes to fit your motor, but the rest should fit nice and snug. Considering we're only talking a 3mm difference over 10cm (metric to make the math easy) or roughly 3/16" over 4" the size difference is negligible.
It's just a practice thing King Theodin88. The Arrow should line up perfectly but from what I've seen not many people get it spot on.
As far as general cutting goes, make sure to do your cuts in a few passes, don't try and push through paper and foam in one go. I'll usually pass over each cut at least 3-4 times before I go right through. Make sure your blades are sharp and held at an acute angle to the foamboard. For cutting corners and curves, don't try and follow the curve around. Cut straight lines past the curve, like so:
See how straight lines can make a curve? This technique HUGELY increased the neatness of my cuts. Good luck!
