Transmitter issues with FC
Grant217
So I’m building my first drone Technically. I’ve helped people build drones before. I just got the Naze32 today and wired everything up correctly with no bridges. So I’m getting signal from my transmitter on my laptop through Cleanflight and I can spin the motors up with the slider bar and calibrated the ESCs. Then I went into the receiver tab and and armed the drone then pushed my throttle up and nothing. So I went to CLI and checked the status and nothing wasn’t not letting me arm so I went back and still nothing. But when I arm it it shows that I’m moving the throttle in the configurator. Idk what to do, I’m in a bind.
ElectriSean
Eternal Student
Not sure what you mean by that... The throttle channel is moving with the arm switch, and without throttle stick input? If that's the case, there's something funky in your Tx mixer settings. If it just won't arm, see below:
Grant217
What I’m saying is when I arm it, the throttle shows in the configuration when I move the throttle stick. But won’t spin the motors
ElectriSean
Eternal Student
Unless you have MOTOR_STOP enabled, the motors will start spinning as soon as you arm it. If they aren't spinning, it's not arming. If it's not arming, the reason is covered in the video above :) Not sure what version of CF you're running, but newer versions won't arm when connected via USB unless you check the "Props are removed" option in the motors tab.
Grant217
Ok I figured out what is happening. The min check is too low. I need to know how to change it in the configuration because I have a DXe and I can’t change the min throttle input
ElectriSean
Eternal Student
From the receiver tab, determine what the lowest value you can get on the throttle channel and add 10
In the CLI, type the following
set min_check xxxx
save
xxxx is the number you get in step 1.
Grant217
Ok I got it to work but two of the motors would rev up unless I gave different throttle input. Then I tried to calibrate the ESCs and they didn’t beep so I went in normally just to see if it would change anything and they just started beeping when I gave throttle
ElectriSean
Eternal Student
Steady beeping indicates the ESC isn't getting a valid throttle signal. This was probably caused by the calibration failure. Once you get them recalibrated, go to the motors tab and spin up each motor individually, slowly increasing from zero. Make a note of what number each motor starts spinning steadily. Take the highest number and add 10 and set your min_throttle to this number. This should get them all spinning when armed.
Grant217
Ok so they won’t go into calibration mode. Idk why. The other three work fine. One of them beeps and doesn’t spin up. Everything else is great. But they rev up by themselves
ElectriSean
Eternal Student
The motors revving up by themselves on the bench with props off is normal, it's the FC trying to adjust it's attitude and failing because there are no props. I'm not sure what's up with your ESC's. What kind are they?
Grant217
Idk I’ll check in tm after I get out of school. I have to go to bed. I’ll get back with you tomorrow afternoon.
