Hi there!
I just wanted to show you my first Tricopter i ever build.
I got my inspiration from David, Flitetest and simplcopter.
I just used swiveling arms for crash resistance as usual.
Material for the deck is 4mm papule plywood.
Arms are made from what i have got lying arround.
Weight is ok i think.
Designed the frame myself by using CAD. (but was inspired by David's design)
Expensive working time for cnc or lasecutting made me do the cutting with my bandsaw.
I just printed the parts out and stickt it to the plywood. Then i cutted allong the lines.
the holes where done by drilling and with the jigsaw.
as i couldn't get nice hinges for the tilting motor i used some aluminium angles and a self bend u shape.
As you can see i used the servo on one side and the 90dg angle on the other side.
this makes a nice free from play connection
here you can get a idear of my dimensions (in mm)
Maybe you like it, then here are the pdf's of it in A4 size.
Print it out 100% !!(whatchout standard setting for printing is 94%)
View attachment tricopter.pdf
!!!! whatchout, there are some errors,
you will need to cut the top layer also so the vertical finns of the tilt-motor fitts!
and you should fitt it to your servo!
Also add strengthening pieces according to your material used for the frame.
Flying video will follow soon.
Yesterday i did the maiden and it went realy smooth
Komponents used:
Tipp for tricopter konfiguration; if you need to reverse the tilting direction of the 3rd motor go to the mixing menü on the kk2.
there change to mixer 4 (which is for the servo) and go to the value that reads 100 and change to -100.
(i searched quite a bit to find this information)
This is it.
Hope you like it.
greetings from Vienna/Austria!
Aquanot
Komponents used:
- 3x TURNIGY Plush 25amp Speed Controller (EU warehouse)
- 2x PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) (EU warehouse)
- 1x Turnigy TGY-9018MG Metal Gear Servo 2.5kg/13g/0.10 (EU warehouse)
- 3x Turnigy Aerodrive SK3 2822-1275 Brushless Outrunner with Short Shaft ( EU Warehouse)
!!! not the optimum!!! - 3x 8x4.5 (1xccw 2xcw)
- 1x Hobbyking KK2.0 Multi-rotor LCD Flight Control Board (EU warehouse)
- 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) (EU warehouse)
- 1xT-Plug (current doesnt exceed 40amps for to long)
- 1x2200mAh 3S1P
- some AWG16 for the distribution
- some plug vor the voltagecontrol of the pack
- some screws nuts and so on
- some heatshrink tubing (ok, more then some)
- some nice zipties = "kabelbinder"
This is it.
Hope you like it.
Aquanot
