Tricopter Random ESC failing
hello
i have a tri copter and i have noticed a intermittent problem. with the escs . occasional one of the motors cut out . it started with the front left motor at first so i rewired everything but now it seems to be a random ocurance on any of the motors . if i cut the power after the crash and restart the tricopter the problem subsides for a while . i dont know if the esc is seeing the pwm changes from the kk as a error or if its something else . but its not a consistent problem.
if any one has some advice it would be welcome
#5
ok i taught that might be the issue but the thing thats getting me is why i can fly for quite a while then all of a sudden it fails
Tritium
Amateur Extra Class K5TWM
#6
Are your props well balanced? Are any of the motors or ESC's getting hot? It would help to know what props and motors you are using as well.
Thurmond
#8
it works for a few min and then cuts out but once i unpulg and replugin it seems to be ok for a few more , im using 2212-13 motors off ebay with apc 10*3.8 props . nothing is getting hot when they cut thats what i cant understand
#14
i will resolder them as i dont plan on using ccw props again . i will let you know if that solvs the problem . i also checked the escs lastnight and they are not atmel so i cant reprogram them .
#18
flew this afternoon . and had no issues with the motors or esc's . thanks guys . does any one have a better plane then cable ties to mount the camera and battery board on a tricopter
colorex
Rotor Riot!
Screws or bolts?
I have bigger plates out of 4mm plywood and use 4M x 40mm bolts.
