I will recommend isolating the issue first - is it on the flight controller or with the motor/ESC:
1. Check whether the motor+ESC of that arm works - you can plug the servo lead directly into the throttle channel of the receiver (bypassing the flight controller) to see if it works.
2. If you find the faults lies with the motor/ESC, check all the solder joints and also try pairing it with other motors/esc to isolate the problem.
3. If the motor/ESC runs fine on its own and the problem is on the flight controller side, maybe you can check the pin positions? Perhaps you can take a picture of the FC wiring and post it here? and others can have a look at it here.
