Tricopter
Shadow74
Multi-rotor madman
The other thing that you could do you, is go to a local hardware store and get a small round bubble level. Stick it on the back of your drill and when your drilling you can watch the level to make sure that it's 90 degrees.
In fact I think there is an app for droid and iphone.... that does this as well.
Just a thought. ;-)
colorex
Rotor Riot!
Even if you drill it wrong, the flat sides of the prop will aid in making it straight. I had/have the same problem.
dezertdog
The specs of the HK NX-4008-620kv Brushless Quadcopter Motor says that the suggested ESC is a 30A, but will it be compatible and working good if I put a 18A ESC? If yes, why?
I'm not really sure why they recommend a 30A ESC... Per this chart, I interpret that it draws no more than 13A in any config listed, it would seem an 18A ESC should work just fine.
Nic
When I'm soldering my bullet connectors, does it bother if the sleeve of the wire go into the solder?
colorex
Rotor Riot!
It's hard to say without seeing it, but it's not a problem if enough wire is well soldered to the connector. The sleeve is just plastic. If you are unsure about it, might as well resolder it.
colorex
Rotor Riot!
Open question: is there a way to limit servo travel on the yaw mechanism? Because there is a physical limit which the servo wants to break. Limiting throws on the Tx is a no go as it messes up the arming procedure.
dezertdog
If I'm picturing what you're saying right, you would do this by making the throw arm / push rod shorter I would imagine?
Nic
yeah but it's in this video that i'm not sure if he's dipping only the unsleeved wire or part of the unsleeved wire and part of the wire. If you don't understand i'll make a drawing for you!
colorex
Rotor Riot!
HAHA yes, on a plane, I would hav done that, but I can't do that as I'm using David's (RCExplorer) direct drive mechanism:
colorex
Rotor Riot!
Sure, make a drawing, or upload a photo! But you need to peel the cable where you are going to solder it.
Nic
When i'm soldering my bullet connector, can the "wire and sleeve" be part of my solder, or I need to peel off some sleeve to make a good solder? Do the sleeve will absorb the current if i'm soldering the "wire and sleeve"?
Sorry for my drawing skills.
Tritium
Amateur Extra Class K5TWM
You must solder only the wire. The sleeve or jacket as it is called is an insulator and will not conduct electricity nor will solder stick to it. Remove it for a length that matches the depth of the connector you are soldering and then use heat shrink tubing to insulate the connector from contact with anything else. Look at other peoples pictures for guidance.
Thurmond
