Hey guys, hopefully someone can help me with a problem. This is my first plane by the way, so if you could talk in simple terms that would be very helpful.
I bought the Bixler 1.1 RTF. Assembled everything. Charged the battery all the way. Hooked up all the channels and programmed the controller by putting the jumper in the BAT channel, hooking up the battery to the ESC, hold the bind button down and then turn on the controller. The receiver stops blinking. I then shut off the controller and unplug the battery and the jumper.
After the programming is complete, I turn the throttle down all the way, and turn on the controller. Then I connect the battery to the ESC. After I do this the motor starts beeping continuously and does not stop until I turn up the throttle a slight amount. The motor does not spin whatsoever other than twitching a small amount in sync with every beep. It's like it wants to spin but is restricted?
Any suggestions?
Thank you!
Any suggestions?
Thank you!
