finnsquared
Greetings!
This is my first post. I've been lurking for a while and I've finally reached the point where I need to reach out for some advice.
So I've just finished building my first FT Spitfire. She looks pretty good considering my limited experience with scratch building. I'm installing the electronics and I've run into some trouble with the motor and ESC I ordered from Altitude Hobbies. Both are from their Spitfire kit.
When I connected all of the components for testing everything worked fine. The motor beeped and spun. The servos sprung to life. I reprogrammed the ESC to match my LiPo batteries. After setting it as a new model on my TX and tuning the settings for the servos (all of which still operate), the motor stops responding. It no longer beeps when I plug in the battery and there is no throttle response. I've gone over every aspect of my setup to find the source of this issue but I've run out of ideas. I don't have an oscilloscope to check the PWM from the ESC which is the only variable I haven't examined. Any thoughts on what the problem might be?
I've added a list of the components I'm working with below. Thanks in advance for any assistance
Spektrum DX6i
Spektrum AR400
Suppo 2217/7 1250kv brushless outrunner
Suppo 30A brushless ESC
Four Suppo SP-90 9g servos
11.1V 1.3Ah 3S 30C Hobby People LiPo battery
Spektrum DX6i
Spektrum AR400
