Turbo Timber Gear Hurt
moret
Take the landing gear and the White part with the 4 screws off. There is a round metal part that the gear screw into that will come off. Get as much epoxy as you can into any cracks even if you need to cut a slot. Get the epoxy as deep as you can. Take a small wood clamp and clamp the part back to the center of the fuselage if needed. The landing gear has a plastic frame inside the fuselage that will break with a hard landing. The pictures are a Timber X but I think the gear is the same. The two timber X's that fly in my area both has had their gear broke off. But then mine had the gear, tail motor etc removed. my brain said up and my thumb forgot he plane was on its back. I have also broke the gear off the new fuselage since the big crash:)
