Hey
I bought the Turnigy Accucel-6 50W 6A Balancer/Charger from hobbyking to charge the batteries for my bixler that I also ordered from hk, but the charger doesn't really work how it shoud or I am doing something wrong
When I'm trying to charge the batteries, there comes the error "BATTERY VOL ERR CELL CONNECT" and in the manual it's written that "There are bad connection at the individual connector. Please check the connector and cables carefully."
If I get this right, this means that the battery doesn't work but I tested the battery with a friends charger and there was no error and the charging worked and there all the cells have the same voltage and I get the same error when I try to charge one of his (good) batteries with my charger...
I made a short video, just to avoid misunderstandings: Video =D
oh and I am using a 12v 0.8A input, I know that the Amps are not enough to charge the batteries but I don't think that the problem is caused by this because I also tried the friends power source which has more Amps.
I am very thankful if you could tell me if I am doing something wrong or if there is a trick to solve this problem, or if the charger is really not working, then I will order a new one
Thanks for the answers!
-Kusti
-Kusti
