A stuttering motor is usually caused by a bad connection on one of the wires from the ESC to the motor. Check those connections carefully and make sure there is a good electrical connection.
Assuming your connections are good, your next step would be swapping out components to see where the issue is. It may be a bad motor or a bad ESC. Switch out each one in turn and see if it works.
