grundrauschen
Hi there, I had my maiden today with my first self built plane - the FT flyer. It flies great, but I noticed something I'm not used to. The Powerpod is equipped with Turnigy Park 300 motor. The motor won't start spinning before giving it about 3/4 of throttle on both 2s and 3s cells. After it started, it behaves normally and only stops if the stick is full down. Is this normal with this motor? Or is the BSC programmed oddly? BSC is a Turnigy Plush, and I did calibrate throttle before flying.
Thanks!
Thanks!
