hello everyone,
I am new here.....but stumbled across this thread on the Turnigy i10.....thought I would chime in a little.....
and toss out some of those Answers some might have?
well to start, if this is your First radio, it will have ALLOT for your first one...for sure get Familiar with it...and if for some reason it did not have a Manual? check out Hobbyking.com on the "International Warehouse" part and it will have the Manual you can download....
also there are some updates, but for some they may not be needed, only if you have a Specific update you might need?
say, for "Quadcopters" it now has an Update you can get will be the "FreeRider" update, and will load a "Multi-Copter" Icon when using the "Multi-Copters" say if you have a Model set as one the Icon will show...
as well, you wont need a separate charger, as you can charge from the USB(Included!) just go to the Menu in the radio and set for it...
sounds complicated? but its real easy, the screen is more such as a Android or the other one?(iPhone...LOL) I hate not having my "Music" as "MY MUSIC" pain in the .......well back to the radio...!!!...LOL
set up is real straight forward, if this is first one, if not then many of Applications will be Familiar !!
when starting ,90% is not really needed? until you get into Mixing different things to do different things on Various Aircrafts...and even then its pretty Intuitive......and easy to check out....
uploading and downloading.....with the "Included" USB....when loading up a "Update"...(If Needed-usually wont?) since has "ALLOT" it can already do...but, you still can load different things, and Modify....as well it works with "FreeRider-Simulator" only about $4.99?
so, go to Hobbyking.com....(International Site- scroll down where they have there "Files Tabs") click and save update you would like.
save to Computer where you can "FIND IT"....then Hook up Radio, will show as a "Drive" on the Computer, let Computer "Find it" and load its drivers, the usual for a new driver etc. etc.
open up "File" you downloaded from Hobbyking.....the radio will recognize it, Load it....all done....it is easier than most.....
I fly allot of different Aircraft, and now the Quadcopters, so, of the Model Memories(20, and can hold as many as your SD Card can hold)
the "Icon for a Multi-Copter shows"....kinda Nice !!
the "Feel" is allot lighter than most !! and easy to get used to.....having both Taranis X9D radios, and Turnigy 9X and "Pro" there all pretty "Comfortable" so getting used to it are pretty Similar to that "Comfortable FEEL" ....so if you had a 9X type, this is easy to get used to QUICK!!...but it is ALLOT THINNER !!!
Gimbals, ARE Bearing Supported !! and is on Par with a $900.00 overpriced radio system !!
now, receivers! I am sure most are Curious? well, as I said have a BUNCH of different aircraft! and some "Inexpensive" parkflyers and other types, so I had a bunch of the Hobbyking HK-TR6A V2 type Receivers, so many might buy those? there only about 8.00 and simple..
"No Telemetry" but they will bind and work with radio, just change its "Protocol" in the menu...and Bind.....
AND!!! it will work with FrSky Receivers, again set the Protocol's from Menu, and bind your all set.....
and then can use All Various Telemitry Receivers, as well as it's "Stock Receiver" already Supports this...and adding sensor Modules "Included" with the radio can also send various Telemitry and can be "Daisy Chained" (linked together) giving it more Options to make it seem like it has more Channels than it has, but can ADD more sensors OR Servos, with the Bus-Adaptor most "Hardcore" flyers will know how to use these, but for ones starting out! there there when and if that need Arises......
Range!,
now with the HK receivers....well? you get what can be expected...even with radio was only able to get about 800 yards...
or for those in the meter thing??? about 804m
in a higher interference area, I got about 600 yards, still a "Pretty Big Area"
with stock Receiver(and a little big for a 250mm Quad) but fine for a 450mm, I got a range of about a mile and 3/4 with no boosters....
so still with interference I got about a Mile easy...or about 1,600+Meters...etc.
and "Average" was about a Half mile radius more than I was ever able to see !!...with FPV Gear, no problem....LOL
the Turnigy iA6 Super Tiny! works on almost anything have one "Inside my Neon-250 Quad" and iA6B-V2 work(the V2 has Telemetry)
and about $10.00 and $12.00 respectively ......so easy on the Budget....
and if already have a few of those FlySky (Not FrSky-but some can work) but if already have a few of the FlySky Receivers TB6A type
same as the HK TR6A-V2 then they can work....
pretty much most with a AFHDS Transmitting Protocol will work and then there are a few places to upload and download stuff to
Change Transmitting Protocol's for Some receivers, such as the FrSky Receivers...and easy to do...
