The B size is for 11x17 sheets, which are exactly twice as large as an A sheet. Large office printers often have this option. If you have access to one, it saves a lot of time because you only have to trim the edges of four sheets instead of two.
Related tip… what trimming the edges of the sheets, user a framing square if you have one. Then you only need to line it up once to trim two edges.
