Twin Tiny Trainer (TTT)
tomlogan1
Redid my Tiny Trainer as a twin, but elected to not use power pods. I did use your idea of using the power nose cut down and used 1/8 " plywood for firewalls. Mine has the 3 channel wing running with 2 x 2300 quad motors and 6x4 counter rotating props. Getting the wiring into the trainer wing was a bit of a challenge as the original spar left little space for the power wires. I doubled the spar and was able to get the power and Y connector in that way. Like yours, the ESCs are housed in the nacelles.
It is really a rocket compared to the first one I built with a single motor. Since it was originally configured for a single motor and the fuselage is one piece, by removing the power pod, there is quite a bit of room for the battery.
No landing gear on mine, but it really jumps out of your hand when you launch it.
