TwitchFrames mini tricopter build
C0d3M0nk3y
I changed the pins on the Naze32. Ground, power, and signal on 1, ground and signal on 3, 4, and 5, and ground and power on 6.
C0d3M0nk3y
Here are the two regulators I'm using:
I soldered the wires on and put some heat shrink on them.
I mounted both regulators behind the PDB. I stacked the smaller one on top of the larger one. They're both held in place with velcro. I have the three sets of signal and ground wires from the ESCs plus the 5V and ground output from the regulator that will power the FC and rx in one 5x2 housing. I used a 5x2 because I didn't have any 4x2 housings. I put male pins on the 5V and ground outputs from the other regulator and a wire to use for the servo signal, then put those pins in a servo extension housing that the servo can plug into directly. There's a 1 pin housing on the other end of the signal wire to plug into the FC. Here's what everything looks like before installing the Naze32:
jipp
what gauge of wire should I use for the battery and ESC? i bought a pack of 10 XT60. i need some wire. to throw in my box for my next project. ( slowly adding bits and parts than i can use for my next build i have two spare PDB cause i thought i ruined the one im currently using on my 250 )
chris,
C0d3M0nk3y
chris,
I've been using 14 for the battery connector and 18 for ESCs.
C0d3M0nk3y
Everything appears to be working correctly.
Now I need to do some tuning and turn those rates up to a reasonable level.
cranialrectosis
Very cool. Glad to see you in the air without problems.
I am totally jealous of your grass too. :)
We have another 30-45 days to go...
