RedDwarf FPV
Hello I just recently built my first quad copter. I am using the lumenier alpha flight controller with 4 in 1 esc. The very first time I hooked up the battery one motor started twitching right after. I did not play much attention to it since it flew just fine. Now it can take several seconds up to 30 to have the esc beep than start twitching before that it won't arm. Or a different motor starts twitching shortly after hooking up the battery causing the previously twicthy motor not to work at all.
I tried fixing this in BLheli but when I connect the configuration options don't appear.
Are there any solutions to this besides getting a new all in one and flight controller
Edit: added vids
The original motor thats is twitching only before arming:
the second issue when the second motor twitches and the original doesn't do anything:
Edit: added vids
