Twitchity
Little update, I've been working on a few ideas for an FPV pod and came up with this prototype. Overall I'm happy with how it turned out for a prototype, but I think I'll be making a few changes to it for the next one I cut. I'm going to remove the bottom standoffs/bolts since they seem kind of pointless. The vertical plates on the pod lock into slots cut in the cage so they won't need the standoffs to keep the bottom separated. This will also allow the vtx to be fastened to top part of the cage under the camera with plenty of room to spare.
The two standoffs on the top will be there a Mobius can get mounted. The shown configuration is for the FPV camera and Mobius at a 30* angle. There is another hole to lower the rear standoff to make the angle 45*, but I'm not sure if a Mobius will fit between the plates since the distance is 35mm inside to inside and the Mobius is just every so slightly larger than 35mm. The two rectangular slots are for zip-ties or thin velcro strips to hold the Mobius in place.
There are also two positions for the FPV camera; one at 30* (pictured) and one at 45*. I'm thinking about changing the zip-ties that hold the pod to the cage around a little, but I like the idea of them being a weak point in a crash so the pod itself won't get destroyed. Another thing I'm not sure about is the standoffs to use for this setup. My quad uses a spektrum sat receiver and is extremely small so 6mm tall standoffs work just fine, but others who have a FrSky receiver will need longer standoffs for the cage/pod to clear.
