Twitchity quad with power board - test build
Twitchity
Nice progress, jhitesma. The KISS ESCs still look big on this frame even though I know they are extremely tiny. Also, I didn't know you had Spektrum equipment; I always thought you were FrSky only for some reason. I love the look of that little satellite receiver on top.
jhitesma
Some guy in the desert
Nope, FrSky is about the only popular setup I don't have (that and graupner)
Actually all three of my quads use different RF setups :D This one I use the sat because it's the smallest one wire option. The 250 FPV I use my openLRS because I want the range and telemetry, and my knuckle I use my homebrewed FlySky (not FrSky) because it's cheap and that whole platform is one big experiment!
Does make it a bit confusing when I fly though...have to keep remembering which module is needed for which airframe! Spent 30 minutes the other day debugging the knuckle trying to figure out why the RX wasn't working before remembering I had the wrong module in my TX!
jhitesma
So...got my big work project taken care of, got the house cleaned up...and had to pick my daughter up from school because she tried to hit her teacher and stuck her tongue out at her other teacher when they tried to reprimand her :mad:
So my day has not been very great.
But she's down for a nap now and I had a about half an hour until my parents are supposed to arrive...so...I took things apart, soldered on the power wire, and gave it a go.
Bad news - as soon as I plugged in the pack I heard a tiny little "crackle" and saw a tiny little spark and puff of smoke from one of the ESC's (one of the ones cranial had previously soldered - I only used one of the new in package ones so far.)
Uh oh. But always being up for doing something stupid I didn't let that stop me...I mean, the light on the ESC was on and no more smoke came out. So what they heck...let's arm....and...they all spun up!
As I've come to expect from KISS they were wonderfully silent! The DYS motors actually sounded good for a change!
But when I disarmed that one kept spinning. Hmmm...
One was going the wrong direction and upon inspection I noticed that the J2 jumper to reverse direction had been soldered on it. A quick zap with my desoldering braid and they were all turning the right direction - so I threw caution to the wind and put some props on.
This time when I powered up the one that worried me didn't light up. Uh oh. But then suddenly it did...and it kept spinning even when disarmed again. Hmmm....
Continuing to push the bad idea I took it out side and did a quick test flight. It flew. It still wants to fall over when I drop throttle...so I'm still not sure what it is about the tune or setup on this quad that's causing that....I haven't had that problem on any of my others but every build with these motors on a 250 had done it for me. It was also just flying kind of bad....but with one funky ESC I wasn't shocked by that.
May try and do a calibration ... but won't have time to swap that goofy ESC. Did get a little video but not sure if I'll have time to upload it or not. More later...but maybe a long later ;)
cranialrectosis
I have two words that need to follow that copter around indoors and outdoors so long as you use those ESCs......'FIRE EXTINGUISHER'.
cranialrectosis
There are a few I soldered the direction jumper on. If I soldered the direction jumper then that ESC has been synched, the motor tested for direction and the ESC spun the motor on my desktop using Baseflight. For it to be smoking on your desk means it failed after my testing.
This is one of the most disapointing aspects of these fails is that they test out ok and then fail later on.
When I removed these ESCs I wore a wrist strap for building PCs...
jhitesma
The one that may have puffed some smoke wasn't the one that had the jumper soldered. But it wasn't one of the ones new in the package.
Didn't have any time to look at it today and won't have time again until at least Thursday. Will probably be out of most communication until then after tonight.
Did get to fly the knuckle with my dad for about half a pack in the yard this afternoon. Unfortunately I got a bit too ambitious and hit a post breaking the front boom :( Probably won't have time to repair it while he's here either.
On the upside we got a door and two windows made for my daughters playhouse so it was a good day :D
jhitesma
Well, had a great visit with my parents. Didn't get to fly with my dad though he was fascinated by the quads. I flew the knuckle in the backyard just a little and managed to smash it into one of my RV shade posts when my skill ran out trying to show off how I could slalom them. Just 2 minutes into the demo flight I had a broken prop and arm. Oops.
They left last night though and today has been spent mostly catching up on things that got put off all week. When I got a few free minutes though I cut up a new boom for the knuckle and flashed MW2.3 in ESC calibration mode to the nanowii on the twitchity - let it calibrate the ESC's, then flashed the special nanowii with oneshot back to it (one shot still disabled for now.) and did a test flight:
The goofiness is gone! I'm still on stock default PIDs so it's not flying particularly well...but it's flying. And sounds great in the air.
I tried tuning it just a little but I can't get my android app to talk to the modified nanowii version of MW and got tired of going inside and outside to tune. My parents left behind two old notebooks but they're both really old XP machines and are loaded down with so much junk they're basically unusable right now. Will have to wipe them before I can use them. But one is a nice small dell that should be quite nice for field tuning on advanced setups.
Unfortunately it looks like I need to pull the trigger on having Twitchity cut me some CF arms. Once I started raising the PID's it started flying better and better...but then I hit a point where suddenly the arms start to flex and it gets some nasty oscilations. I can actually hold it and see the arms flexing. But I can't really spend that kind of money until after Christmas. So I'll have to keep the tune kind of mild for now and try to restrain myself for a few more weeks ;)
jhitesma
And...what the heck. Since the theme of this quad seems to be bad ideas I went ahead and swapped over to one shot after just 1/4 pack of flying/tuning with it setup normally :D
I also finally protected the ESC's a bit - 2" of "clear" silicone self fusing repair tape since I'm out of the proper sized shrink wrap.
Passed the bench tests. Need to get it out to fly. Only major issue is it seems the nanowii build of MW doesn't have failsafe...or at least it isn't a sensibly configured failsafe. There's no options for it in the config.h even though I still see some failsafe stuff in the code. Testing it confirms no active failsafe.
So I may grab motomoto's build of 2.3 for the motowarp board (which is based off the same setup as the nanowii) for the familiarity - that's the only other option I can think of to keep oneshot.
Still love how much better this sounds with the KISS ESC's. Wish I could afford to put them on everything. Apparently cranials curse hasn't followed me despite that one little mysterious spark and puff of smoke I saw on first power up....fingers crossed.
cranialrectosis
Oneshot is the creation of Flyduino and from their UltraESC page:
"In cooperation with a Nanowii Oneshot PWM mode can be used too , this provides a ca. 8 times faster transmission ."
http://flyduino.net/UltraESC-20A-2-4S-ESC_1
As I understand it, Oneshot eliminates redundant re-transmissions of the last instruction from the flight controller and only sends new updates to the ESCs thereby reducing latency and giving the pilot a more 'locked in' feel.
FGA is a fan and has recently published this:
http://forum.flitetest.com/showthread.php?14314-OneShot-on-Naze-32-(Cleanflight)-comparison
I am glad these ESCs are working out. My issue had to be ESD caused by the extreme climate in which I live. I think it literally came down to which shirt I was wearing when I installed them deciding if the ESC would explode or just work.
jhitesma
Oneshot is basically a different way for the FC and ESC to communicate. It's a bit complex to explain but effectively it makes it possible for the FC to send updates to the ESC much quicker because of the change in how the information is sent.
Twitchity
The quad looks to be flying much much better with those KISS ESCs. Now you'll be wanting to get a CF frame and 2204's.
jhitesma
Yep, at least on the carbon...I'm not in as big of a hurry for the 2204's now though :)
I flew another pack in the yard today with a more aggressive tune and the biggest problem now is that I have a very small usable throttle range. Hovers just below mid throttle...but any lower than that and it tips and falls rather than descend nicely. And any higher than just above mid and it starts to oscillate from the arms flexing.
The DYS motors now stay nice and cool even with the 6045's on there - after a pack of the most spirited flying I can do in the yard they weren't even warm. Of course it was only low 70's out today not low 100's which I'm sure had a bit to do with it...but before with the BS12's I was worried about the temp on the motors after half a pack of hovering as they were too hot to hold comfortably for more than a few seconds.
Still not sure how to address the low throttle issues...I've had that problem on my ultra budget 250 frame with these motors, this frame with these motors and to a lesser extent my emax 250 with the emax 1806's. But I didn't have that problem on the warp with the 2204's. I'm guessing it's something about the torque of the 18mm motors compared to the 22mm motors but I'm lost as to what if any kind of tuning I can do to assist. I'm wondering if raising the minthrottle or tweaking the throttle midpoint may help. Will have to do some experiments the next few weeks.
The high throttle issue is a pure limitation of the thin G10 arms. It either needs thicker G10, carbon arms, or some kind of reinforcement on the current arms. Actually there is one other thing - right now the FC is hard mounted on the nylon standoffs. I may try adding some o-rings to see if a bit of isolation helps. It won't solve the arm flex - but it could be the arm flex is due to the motors changing RPM so quickly trying to compensate for vibration it's picking up. So I'll give that a try before doing anything more drastic.
The tune still isn't perfect...but it's able to flip now and is responding much better. If I can work out these issues and expand the throttle range a bit more it will great. Would love to see what it does at full throttle, does a pretty good disappearing act already!
jhitesma
Popped some O-rings under the FC at lunch today and flew a pack in the back yard. Definitely seemed to help a with the high power oscillation but didn't eliminate it. Just boosted the point in the throttle where it occurred.
Still, I was able to push the P terms a bit higher and get a bit more responsiveness from it as a result. I also tweaked the throttle midpoint to try and help the low end and it seemed to help a bit. Need to do some more experimenting but the tune is definitely improving.
The thin G10 arms are definitely a limiting factor on performance at this point. They're holding up just fine to crashes - but the flex/vibration in them at higher power is really showing now. Wish I could pull the trigger on CF already :D
jhitesma
Had this out this morning and flew a few packs with my friend who had me help build his warp. Had a few tune issues that kept getting worse, but backing off the P gain solved them. We both gave it a few good crashes and other than a couple of broken props there was no damage.
I also loosened the nylon FC mounting screws just a little so there wasn't as much compression on the o-rings - and that helped as well. But proved to be a bit of a mistake as after my last crash I picked it up and noticed the FC was dangling. Not sure just when the screws came out but looks like I need to hit the hardware store for more nylon screws and o-rings before I can fly it again!
Should have some video later tonight, have to download and edit it. Shot with two cameras even this time :)
I'll just leave it with this shot of one of the more spectacular crashes of the morning:
He was up pretty high and lost orientation which got us both nervous as I had forgot to warn him failsafe isn't working on this FC yet! He started to bring it in, but then lost it again and hit the ground hard from pretty high up. At first I thought he landed on the other side of the fence and had bounced into the canal visible in the background :eek: Then as we got closer I thought he had managed the elusive lawn dart landing - but once we got close I realized the arms weren't stuck in the ground it was just leaning on the fence :( Still it was a HARD hit and the only damage was a bit of sand in one motor and one broken prop.
This frame really can take a beating!
I'm also starting to think the issue I'm having may not be as much due to the G10 flexing as it is vibration affecting the FC. Fresh props and loosening the FC mount screws helped as much or more as lowering the P gains did. I have a few ideas on how to mitigate vibration more when I remount it. We'll see how that goes.
Loving how the KISS have this little guy performing now though! Thanks again Cranial...I'm starting to have second thoughts about putting these ESC's on the hex now...may need some nomex to line my wallet pocket with (Gotta pay off that last card before I can splurge though!)
cranialrectosis
I use the full sized O rings and a nylon screw long enough to sandwich the board above and below with O rings. I use 8 O rings per board and haven't had any trouble with them.
The short screws or the flatter O rings don't work as well. The thinner, flatter O rings seem to be harder rubber. I get the soft, fat skwooshy type. :)
jhitesma
Yeah, I had been using 8 o-rings, but then had the issue with loosing the screws on the emax and had to steal some o-rings so I was down to just 4. Which I suspect was the issue. Just hard to find the right sized nylon hardware and o-rings here locally, the one shop that usually has them is only only until 6 on weekdays and noon on Saturdays - closed Sundays. And I seldom have time to get to the store before 6 or noon on Saturdays :(
Will try to get up there on my lunch break Monday. If not I have some silicone fuel tubing the right size that may work well - just still need the screws - but might be able to find those at one of the big box stores. They just always seem to be sold out of the nylon hardware and never know when they'll get more in.
Haven't fully reviewed video from the second cam but the mobius hatcam footage seemed good enough to share without any editing:
Watching it I noticed that I was down to just one screw holding the FC on after the first crash. Doh. I knew I should have done a better post-crash inspection! Was just too anxious to toss it right back in the air and show how well it takes a hit and keeps on going.
I seem to be having really bad luck with nylon hardware coming loose lately. First the emax now this. Any one have any suggestions on a nylon safe loctitie sub? Maybe clear nail polish?
Twitchity
I would have been extremely impressed if you were able to lawn dart the quad into that ground especially without breaking anything. That frame is probably begging for you to retire it and upgrade to the CF version with how much abuse you're giving it.
Balu
Lurker
Admin
Can you guys make a detail picture of your O-Ring / nylon screws setup? I'm still using the foam / zip-ties method to hold the controller which worked great so far, but the foamed rubber(?) I got lately is a little stiff, so I'm curious to see other solutions.
Also: Lawn darting is a thing? I've done that twice already, but have to admit it was on a freshly plowed field :). I'm asking, because I think I might be able to become an expert in that area. :)
He will break the frame sooner or later, so he has to switch to CF anyways ;-).
cranialrectosis
I learned this from the Warpquad instructions. I love how it frees up the underside of the flight controller for receivers and cabling.
http://forum.flitetest.com/showthread.php?11915-Twitchity-Mini-Hex-CF-Edition/page4
The photos are about half way down the page. :)
