So I haven't updated this lately. I've been flying the snot out of this little guy despite the damage from the meltdown. Twitchity sent me some replacements arms but for reasons I can't really go into just yet I'm still flying on the original damaged arm. The silicone tape I used to insulate the arms has been working well. It was a major pain to get installed cleanly, and I had to snug the frame bolts a couple of times as it compressed down - but so far so good.
I've even tossed some gemfan 5" props I had laying around on it and have let a few friends with minimal or no experience take it for a few flights. Unfortunately right after new years an arsonist torched or city's amazing "castle park" next to the field I fly at - but making lemons out of that lemonade it means I've been able to fly over the field a lot more since no one is up there. (And the city plans on rebuilding - but they're still investigating the arson, talking to their insurance company and deciding the best way to move forward with rebuilding which likely won't happen until next year.) So we lost one of our prize community assets for a year or so...but I get to fly at the field over grass a lot more since there's no one there now.
Everyone who's tried the Twitchity acro loves it. My friend with a warp had a blast with it, and even the complete noobs had fun once I loaded a profile with tamed down rates and put it in horizon for them. Of course that also means it's taken some really hard hits lately. Just yesterday it had it's hardest hit yet. My co-worker I gave the G10 frame to got to try it but lost orientation and then panicked throttling up instead of down. I eventually convinced him I was serious when I told him before we started that if he got into trouble to just disarm and let it fall which he finally did from about 200m away and oh...70-80 feet up....over pavement.
Ouch. That wasn't just due to him...mostly it was due to an issue I can't really go into just yet combined with a few weeks of hard crashes. He felt horrible but I reassured him I had two replacement arms at home and more on the way. Besides, the fall didn't even break a prop (it did bend one) since we were on the cheap flexible gemfans - so I immediately put it back in the air to show him he didn't really do any serious damage
Worst part of it was I got a CF splinter from the damage
But...today I got a care package from Twitchity:
(Don't mind that balsa in the background...I kind of started
another project I've been meaning to get to for some time...I've been a bit too focused on multi-rotor flight lately and felt a need to take on a project I've been wanting to tackle for about 30 years.)
I've been looking forward to this for a few weeks
The new v3 PDB is exciting to have along with a replacement bolt/nut for one I stripped.
Enlarged gaps between the copper and the holes so the heads/nuts won't short out to the ground plane anymore:
And positive copper removed from under the arms - so both sides of the circuit are now protected from shorting out.
As exciting as the new improved PDB is what I'm really excited about is the new arms he cut for me. This is 100% experimental and something I've been wanting to try since I heard about
picnic quads and the hybrid carbon birch material from DragonPlate they use in their micro frames. Twitch and I have talked a few times about trying this but neither of us were ready to put the money into trying it. I finally decided to put my money where my mouth is and return the favors people have been doing me by financing a sheet to experiment with. So save money I opted for a discontinued size sheet in the matte finish which is a bit cheaper than the gloss and supposedly more scratch resistant.
Here's dragonplates page about this material:
http://dragonplate.com/ecart/categories.asp?cID=3
They claim that it's both stiffer and lighter than solid carbon. Sounds perfect...but let's see how it works in practice! We went with the 5/32" thickness which is about the same as the 4mm all carbon used so far (My calipers put it about .01mm thinner).
Twitch and I are still debating the best way to make some actual strength measurements on this stuff...but initial impression is that it's not actually stiffer as claimed as it seems to flex a bit easier than the pure CF. However it is considerably lighter.
The two biggest issues I have with it are:
1) The bottom is a textured rough finish - not very attractive. The exposed birch around the ends may be unattractive to some people as well. So it's not the prettiest material - but I'll take performance over looks any day.
2) The CF laminations are very thin and I worry about how well the exposed birch on the ends will hold up in crashes. I'm thinking about mixing up some slow curing epoxy and letting it seep into the wood on the ends to help seal it.
Here's some comparisons showing the difference in finish and weight.
DP Hybrid arms on the left - matte side up. Spare DPH arm "textured" side up in the middle. Original matte pure CF arms on the right.
DP Matte finish:
DP "Textured" finish:
Original non DP matte CF:
DP Matte side up at top, DP textured side up in the middle, original matte on the bottom:
I only have 2 unused arms from the original CF so I'm only comparing 2 arms instead of a full set of four...but the original arms came in at 18g for two (so we'll assume, 36g for all 4)
The hybrid CF/Birch arms however came in at just 10g. (so we'll assume 20g for all four) So overall switching from four CF arms to 4 hybrid arms should save 16g overall - nearly half the weight. Not a huge difference but every bit of weight shed is a bit more flight time, a bit more performance and a bit less damage in a crash....
One last look at the DP finishes:
So I'm excited to try these. I'm going to epoxy the ends to protect them a bit and I'll have to sand the sharp edges (the edges are sharper than on the pure CF Twitchity has been using.) so it will be a few days until these are ready to go on the quad. But I can't wait to try them! They do seem a bit less stiff which may or may not be a bad thing...maybe the birch will help absorb vibration from the motors, maybe the loss of stiffness will make vibrations worse. Maybe the wood will get damaged in crashes, maybe the ability to flex will help it hold up better.
Stay tuned. Twitch and I are talking about various tests we can put this material through to see how well it holds up and whether it's a good option or not. It is more expensive than the CF he's been using so the benefits would have to be pretty good to justify switching to it. But it might be something he'll offer if it works out well. Or I may have just tossed away some money on some material that is weaker and more expensive. Either way this is how we learn and I'm always up for learning something new
