Thurmond - thanks for encouraging me to take a look at the power traces again. Just opened up the files and confirmed I was in the wrong units I knew those traces looked too thin. Calculator is showing over 100F temperature rise at just 10a. On the traces I have now
Grrr, really meant to go back and take a closer look at those before ordering, same with the tiny battery holes. Good thing I'm already planning on doing a rev2. Since you've got a rev1 board I'll include you in the review process before submitting them to OSHpark this time. I'd love to hear any feedback you have on the board that I could incorporate into the next revision. Rev2 I plan on having most of the bottom layer as a ground plane and most of the top outside of the FC mounting holes as a power plane. The area the FC mounts over I'm trying to keep clear since that's where I plan on putting a built in FC in the future.
One thing I also noticed on the board you may want to watch for. The board outline is not 100% symmetrical. It's close, but not perfect. I actually noticed this in Twitchity's original files he sent me when I was drawing out circuit designs by hand. I held two printouts up to the window to trace some earlier ideas and found that rotating one 90 degress caused a slight misalignment between them. And I noticed the same with the PDB. Bolt it up one way and it lines up perfectly with the lower plate used as an upper plate. But rotate it 90 degrees and it's just under 1mm off. Still fits fine but hangs over on one side a tiny bit and comes up short on the opposite side. Not really noticeable unless you're looking/feeling for it (I can feel it more than see it it's such a slight mismatch) but since you seem like someone who likes to take their time and get things "just right" I thought I'd warn you to watch for it
