I see more Jolly Ranchers in my future. I need some props anyway.
On the next PDB please use a resistor for each of the leds. That way they can be selected based on the requirements of each led if one wants to use different colors. The current scheme at best supports one color pairs and I would like to run 4 different colors. Running red on left and green on right with 270 ohm flea sized resistors will not let the front (blue) or back (purple) light. These resistors should come with an inhalation hazard warning.
I came very close to doing that...but wanted to keep things simple. I was also thinking about adding pads for LED's on the bottom since they'd be more visible - but also more easily damaged.
On another note I would like to try some KISS esc's but not at $100 for a set. TOO rich for my blood. Possibly when my skills improve (if they ever do that is ) and I go to insanely expensive motors (T-Motors) then insanely priced ESC's might make sense, BUT not Today! Does KISS stand for Keep It Steep Sales?
I can't afford them either...but having experienced them...I'm going to find a way. The change they made in that warp was so astounding I just have to get some for myself. The Twitchity right now (when the motors run smooth) on HQ6x3's is flying about like the warp did on HQ5x4's when it had the BS12's. It's not the blistering performance you expect from a fully tuned out and properly propped warp...but it's still pretty impressive. So I really suspect that swapping to the KISS would give it that same incredibly locked in feeling even if it still doesn't have the same top end (at least not until I can find funds for some 2204's.)
But here's the thing. I would rather put $100 into some KISS's for it with the DYS1806 motors even with the bearing problems I've been having (which REALLY have me wanting to swap motors right now) than put $110 into some 2204's. I don't need the eye watering blistering performance the 2204's can give. But I know I can fly a lot better with the super locked in feel that the KISS's give.
Kind of like on my dune buggies where I'm more interested in improving the handling and brakes than I am upgrading the motors. Power is nice...but having control first is key. The KISS's give amazing control and are where I'll be putting my money once I can save it up.
You may find Jhitesma that it may be the esc hardware themselves. Those BS12a's don't tend to like repeated hard hits and components on the PCB start to fail.
Agreed on the SimonK/non SimonK comparison with the KISs ESC's. Particularly for a high powered acro quad the difference is amazingly huge.
SimonK by default runs at 400hz so the default motor_pwm_rate of 400 should be fine but if you haven't already, adjust looptime in the naze to 2500 to get it doing it's thing at 400hz also.
Just to add to that I'm in no hurry to rush out and buy KISS's for my knuckle quad. I'm sure I'd enjoy the change - but it would feel kind of like putting a tuned twin turbo V8 into a rusty old minivan. Yeah, it would improve the performance...but the overall package would still be lacking and there'd be a lot of potential performance being wasted.
But on a mini with high KV motors that's flown LOS for acro...I just can't see myself going without KISS for very long. It may take me a month or two of minimal hobby spending to set the funds aside, but one way or another I plan on having KISS esc's on this guy as soon as I can pull it off.
