OK jhitesma, I got the berings and I have replaced berings before but...how did you get the old berings out of the DYS 1806s?
I do have the C clip removed.
I've been happy with the bearings I got from Avid. I just recieved my second order from them today.
I just ordered 10 bearings from Avid, so I'll give them a try. I have two motors that are noisy so I figured I'd order some spares as well.
As far as the roll situation goes on my quad, I tried looking for some way to adjust the endpoints on my transmitter (DX6I), but I can't change anything outside of adjusting the travel adjust(?) to 125% which has already been done. Doing so I get a low reading around 1050 and a high of 1850 with mid being 1500.
Since I can't go in and adjust the high/low points individually, would adjusting the mincommand to 1150 and maxcommand to 1850 fix my roll problem? This way I would have 350 difference from low to mid, and a 350 difference from mid to max.
When you get to the travel adjustment screen move the control stick in the direction you want to adjust the travel and then you will see the arrow displayed next to the aileron/elevator change to match the direction you are adjusting. This should allow you to set a different endpoint for each direction.
Those are some pretty nasty looking bearings which like they have been used and abused
mpbiv, that worked on my transmitter. I can now do rolls in both directions, thank you
Thanks for the link, jhitesma. Does Avid have JollyRanchers though?
Thanks for the lesson, FGA.
I love this line "It is a good idea now to mark the old bearings with a black marker so you don't mix them up with the new bearings." There's a lesson learned from experience.
