Spitfire76
I install an Aura 5 Lite in all my planes and I am currently migrating my RX's to Radiomaster with ELRS. I have a TX16s running EdgeTX with a Radiomaster ELRS TX module. Some of my planes have flaps and some have retracts but at the moment none have both. I can't be the only one using this combination so I am starting this thread to discuss configuration.
Let's start off with some links to setup and configuration resources
edgetx.org
www.expresslrs.org
github.com
wiki.flexinnovations.com
Some basics.
store.flitetest.com
EdgeTX
edgetx.org
ExpressLRS
ExpressLRS is a fully open radio control link built for maximum range, speed, and data throughput. Wide hardware support across both 900 MHz and 2.4 GHz frequencies.
GitHub - ExpressLRS/ExpressLRS-Configurator: Cross platform configuration & build tool for the ExpressLRS radio link
Cross platform configuration & build tool for the ExpressLRS radio link - ExpressLRS/ExpressLRS-Configurator
Aura 5 Wiki - Flex Innovations Wiki
FT Aura 5 Videos - Flex Innovations Wiki
Some basics.
- The TX should not be configured with rates or expo as they are handled by the Aura.
- All TX trims should be centered to start with and any trimming made during flight transferred to the Aura.
- Aura does not support CRSF, so RX must be setup to output s.bus to the Aura.
- TX sticks are mapped to control roll, pitch, yaw and thrust.
- The Aura 5 lite has 5 PWM servo outputs
Flite Test Aura Lite
Stability meets agility with the 6-axis Aura 5 Lite Controller. Easy configuration, powerful features, flexible design and set-up.
