It maidened! Sort of, to be honest. LOL More like a crash with dignity.
The day is beautiful, clear skies with only an occasional puff or two of wind. So I headed out to the fields to give it a go. After a couple of aborted takeoffs, I managed to get it in the air on the third try. It got up about 50 feet, went out about 200 feet, kept rocking back and forth, and finally just rolled into the ground. The nose cap and the front canard took most of the damage, but the black foam in the nose did it's job and cushioned the battery from the blow.
Mistake #1 - I had set it up for aileron-elevator mixing, as I didn't think I had enough throw on the canard control surfaces to be effective. Wrong - I actually needed those front elevators. I had to manually push them down about 15 degrees just to get the plane to unstick from the ground on takeoff. With full RC front elevator control I should be able to take off at a slower speed.
Mistake #2 - My battery wasn't fully charged, so after all the aborts, when I finally got it up there, it just lost power at the end and I couldn't recover. I wasn't ready for total loss of thrust, so that is something I need to watch out for in the future.
I've repaired it, but considering how wonky it was in the air, I think a complete rebuild is in order. I need to reinforce the canard, give it some dihedral, and full flying control surfaces. As for the rear wing, I think adding true air foil would give me more lift.
